Hi
What is the best way to do this so I can preserve my layouts and settings, etc please.
Many thanks...
Moving to a new Mac from an old one
tonyt
Re: Moving to a new Mac from an old one
Nyone give me some advice? Thanks!
I don't install xnviewmp, I'm using portable (zip) version on Windows, and i always select "same directory as program" to store my settings.
So, I look for the most recent files in xnviewmp directory, and i copy them into the new location for a new version
(.ini files, .db files, .qss files, .dat files, default.keys, default.bar)
but
- Don't know if "install" means anything in Mac os
- Don't know if "portable version" means anything in Mac os
- Don't know if you could choose a place for your settings, or if they are stored in a system directory (see Settings, integration, paths)
but
Catalogage avec XnviewMP :
tonyt
Many thanks, still not clear so still looking for help!
Cheers..
Cheers..
surftom
Go to Settings -> Integration -> Paths
open the config and file catalog location, copy all the files
Install the app on the new mac then copy the files back to the same locations
Make sure your media is in the same path as your original mac
T
T
