It would be nice if the Move dialog has a "Create new folder" button so it would allow to move files/folders to a new folder, creating it on the fly.
I will post the same suggestion for XnView Classic, since I use both.
Thanks again for those very nice pieces of software!
Jean-Louis
create subfolder in Move dialog
Re: create subfolder in Move dialog
While there is no such button you can simply type the complete new path into the input field. Then the folder gets created on the fly.oneto wrote: Mon Jun 10, 2019 4:24 pm Hello,
