Hello.
I've tried to assign a shortcut to the cmd_showRecursive and I can't make it works
It can be added an option that can show all the content (recursive) of the current folder or selected folder and assign it a shortcut?
By the way......When it's the nxt update programmed?
Thanks
Shortcut for Recursive search doesn't work
ThunderWarrior
Re: Shortcut for Recursive search doesn't work
any shortcutThunderWarrior wrote: Thu Jun 13, 2019 8:03 am I've tried to assign a shortcut to the cmd_showRecursive and I can't make it works
August i hope...By the way......When it's the nxt update programmed?
ThunderWarrior
Hello Pierre,
Thanks for your answer. Congratulations for your work and your fabulous application.
I don't understand your answer of "any shortcut". It's possible to do it? If actually can't be, do you add in the next update?
Nice day friends!
Nice day friends!
do you have tried other keys?
ThunderWarrior
Ohhh. It seems with othre keys works. I'm sorry to disturb you with this when was my mistake.
Perfect then.
Thanks for support!
Perfect then.
Thanks for support!
