Replace color -> Tolerance not working
101Bram
Post by 101Bram »
When I change value tolerance in the replace color action, it has no effect.
MacOS 10.14.5
XnConvert Version 1.80 - x64 (Mar 5 2019) - Libformat version 7.30
Re: Replace color -> Tolerance not working
on which image do you try?
murahikaru1210
Post by murahikaru1210 »
I am having the same problem,
I am using XnConvert Version 1.80 - windows x64 (Mar 2 2019) - Libformat version 7.26
OS version Windows 10 Home Ed, ver 1803
when trying to replace the green background with white in attached picture, it only removes the color I selected from screen,
regardless of the tolerance settings from 0 to 100; even after I removed the green channel and turned it into grey scale,
it still only replaces the grey color I selected, please help.
Thank you for such wonderful software, and thank you for helping us! :D
original file
original file
which color do you use?
Jarlaxle
Post by Jarlaxle »
I have the same problem:
File I try to convert:
I try to change the blues into violets/indigo without touching Gold, and turn off all alphas/transparency. The second part (turning off alpha) work, tolerancy on color change, not so much.
Subject: 0.85: Batch Convert -> Color Change Tolerance
XnView MP 0.93.1 - 64 bit
OS: Windows 10 64bit
1. Open XNView MP
2. Choose file to Batch Converter Lucius_2_leather_warfrontsalliance_d_01_gold.png
3. Choose
4. Chose in Action, Change Color -> color A from screen blue; color B Indigo; Tolerance 100 than 50
Actual behaviour (bug): Change only of exact color, no matter the number in tolerance :bug:
Expected behaviour: Change of colors and similar ones
Jarlaxle
Post by Jarlaxle »
I was helpfull :D . Thanks for everything.
