"Lock Zoom" only works the SECOND time you activate it
Lee James
Post by Lee James »
I'm viewing images full-screen. I right click and select "Lock Zoom". The zoom does not lock. If I do the same again, it works the second time.
I'm running Windows 7 x64. XnView Version 0.93.1 - but this bug has been around for a while now I think.
Lee James
Re: "Lock Zoom" only works the SECOND time you activate it
Post by Lee James »
By the way, if you enable "Lock Zoom" twice in a row, it still won't work.
To make it work, you need to do "Lock Zoom" - then do some zooming - and then do "Lock Zoom" again.
i can't reproduce. I open a file in fullscreen from browser, change zoom, lock zoom, next file will have same zoom value
