ARM64 support for Crostini
MysticDaedra
I'm trying to install XnViewMP in Crostini on my Lenovo S330. Unfortunately it keeps giving me dependency errors, also saying that the dependencies cannot be installed... Is this standard? I've tried the file in the 0.93.1 thread as well as the recommended 0.92 thread. Nothing seems to work. Thanks in advance!
MysticDaedra
Support for Crostini?
Not sure if my first post was deleted? Anyways, I'm trying to install XnViewMP on my chromebook via crostini. Unfortunately, it doesn't seem to be compatible... I've tried all the ARM versions, I've tried the normal x64 version, nothing seems to be working. Any help? I'm using a Lenovo S330 Chromebook, tried installing by double-clicking the .deb and by running sudo apt install ./XnViewMP-linux_0.92_armhf.deb
