Hello.
I need to find all the corrupted images in a folder and its subfolders.
Trying
>nconvert -fullinfo C:\Users\xxx\Desktop\image_1.jpg 2>Nul
on one of these images, I get
and I don't get
Title:
Is there a way (from command line or also in another way) for finding out all the images that will have the same problem?
Thanks!
Luigi.
detecting corrupted images in a folder and its subfolders
solquest3
Re: detecting corrupted images in a folder and its subfolders
could you post an example of corrupt image file?
solquest3
You can find it attached.
Thanks!
Thanks!
attached where?
solquest3
Hmmm true..
When attaching I get the error "The upload was rejected because the uploaded file was identified as a possible attack vector."
You could try putting it in a ZIP or similar archive, that might work...solquest3 wrote: Thu Jul 04, 2019 8:51 am When attaching I get the error "The upload was rejected because the uploaded file was identified as a possible attack vector."
solquest3
Here it is now.
Thanks!
Thanks!
when using -fullinfo, you have 'XXXX : Failed'
