I see that Xnview can read the HEIC files, but not the EXIF of HEIC files.
Is this something that will be addressed or are there obstacles difficult to overcome ?
Thanks,
Alberto
Exif on HEIC
Re: Exif on HEIC
currently i have no way to get EXIF, but i'll search for
apworks
Re: Exif on HEIC
I have used "exiftool" to successfully read/write exif on HEIC.
Re: Exif on HEIC
could you send me one sample?apworks wrote: Thu Jul 04, 2019 11:01 am I have used "exiftool" to successfully read/write exif on HEIC.
apworks
Re: Exif on HEIC
Hi, I just used the windows cli executable, not the Perl library.
The sequence reads current "ImageDescription" tag, then changes it, then reads the new value.
C:\path>exiftool -ImageDescription IMG_0000.HEIC
Image Description : Test 123
C:\path>exiftool -ImageDescription="Test 456" IMG_0000.HEIC
1 image files updated
Image Description : Test 456
