Ulead UFO (Ulead File for Objects) support
herwigv
Is it possible to add the import format Ulead UFO (Ulead File for Objects)?
Re: Ulead UFO (Ulead File for Objects) support
The problem is that it's a closed format...herwigv wrote:Is it possible to add the import format Ulead UFO (Ulead File for Objects)?
Owner...
¤ Also so-called "Owner-format", it's a format which belongs to a single Company that doesn't provide any technical information about this format…
- Hence, it's pratically impossible to add a support for it…
Re: Owner...
Another term that comes close to "Closed format" is "Proprietary format".Clo wrote:Hello !
Kind regards,
