Hello
I use XnViewMP daily with Riot.exe that compresses images and renames original version to imagexyz.jpg.orignal by adding ... you get it...
Thing is I can not exclude these from image viewer/browser no matter I try.
Is it possible for Xn to scan only for the first occurrence of "."extension and therefore finds .jpg and exclude filter is skiped?
Exclude filetype .jpg.original
Re: Exclude filetype .jpg.original
you can add .original in settings>File list>Custom filter - exclude
pedalracer
I got it. Sorry, I missed to set view then to "custom view". I thought these filters work in general.
Thanks
Thanks
