Error when converting RAW batch
Juha
I might found an error in XnView. I converted batch of Canon RAW files to JPG and made on the same time some brightness adjustments. Error is that created images that are more high than width are turned 90 degrees.
Re: Error when converting RAW batch
And when you load them in XnView?Juha wrote:I might found an error in XnView. I converted batch of Canon RAW files to JPG and made on the same time some brightness adjustments. Error is that created images that are more high than width are turned 90 degrees.
