Folder - rename batch
Anderson64
Post by Anderson64 »
Hi, my name is Anderson and I'm new here in this forum.
I have changed OS from Windows to Linux.
At the time I was using Windows the software I used most was XnView.
On Linux you have XnViewMP, but XnViewMP does not batch rename the folder.
Because of this, I am required to use VirtualBox to run Windows 7 with XnView.
Tip: Add XnViewMP the ability to rename a batch folder.
Thank you for your attention.
m.Th.
Re: Folder - rename batch
Post by m.Th. »
Try this:
Select the files which you want to rename and:
- Press F2
- OR -
- Go to Tools | Batch Rename...
m. Th.
