Currently, v 0.93.1, in the Folder pane, all folders have the same colours.
It'll be nicer that the folders in the active path could be set in another colour, so that you see it faster when scrolling.
Example of folder structure:
folder
+subfolder1
++subfolder1_1
++subfolder1_2
++subfolder1_3
+++subfolder1_3_1
+subfolder2
Your current path is : folder\subfolder1\subfolder1_2\
Then subfolder1_2 and subfolder1 could be set in another colour than all others.
https://i.stack.imgur.com/13KPa.png
Thanks
In folder pane, the active parent ought to be in another colour
mustbeit
