SaveBitmap problems
Alessandro
SaveBitmap problems
Post by Alessandro »
1) I tryed, using AllockBitmap(), to alloc an RGB32 image (both abgr and bgra) and the image wasn't correctly saved into any formats.
I got in every case a white image.
2) I tryed to save into a gif a RGB (24 bits since 32 doesn't work...) image and SaveBitmap() asked me to convert the colorspace.
SaveBitmap() could call itself colorconvert() if it recognizes a bad colorspace for the requested output format, and btw there's now way (maybe... am I wrong?) I could know what's the maximum colour depth for every format, I mean...I know it's 8bits for gif, but I dunno if other formats have the same limitation.
If actually there isn't a way you could add such a field into the structure that returns info about fileformats.
Best regards.
Re: SaveBitmap problems
Alessandro wrote:Hi,
Could you post your code?
You can use GFL_SAVE_ANYWAY
Alessandro
The following code works because I modified it to save rgb24 images.
CopyFrame() was the function that I previously used and you can think of it like a memcopy() applyed on every row since Image is a rgb32 image.
int MySaveImage(const char *filename, char *FormatName, DWORD *Image, DWORD w, DWORD h, DWORD pitch, bool IsGray, bool flipV)
GFL_FILE_INFORMATION info;
GFL_SAVE_PARAMS save_params;
GFL_BITMAP *pBmp=gflAllockBitmap(IsGray ? GFL_GREY : GFL_BGR,w,h,IsGray ? 1 : 4,NULL);
 if(pBmp==NULL)
  return GFL_ERROR_NO_MEMORY;
// CopyFrame((DWORD *)Bmp->Data,Image,Bmp->BytesPerLine,pitch,h);
 RGB32ToGB24(pBmp->Data,pBmp->Width,pBmp->Height,pBmp->BytesPerLine,Image,pitch,flipV);
 gflGetDefaultSaveParams(&save_params);
 save_params.Flags=GFL_SAVE_REPLACE_EXTENSION;
 save_params.FormatIndex=gflGetFormatIndexByName(FormatName);
 save_params.Compression=GFL_LZW;
 save_params.CompressionLevel=7;
 save_params.Quality=75;
 save_params.ChannelType=IsGray ? GFL_CTYPE_GREYSCALE : GFL_BGR;
 save_params.ChannelOrder=GFL_CORDER_INTERLEAVED; // for raw format
GFL_ERROR retVal;
 if((retVal=gflSaveBitmap((char *)filename, pBmp, &save_params))!=GFL_NO_ERROR)
  gflGetErrorString(retVal);
//  MessageBox(NULL, "Error saving file!", NULL, MB_OK);
  MessageBox(NULL, gflGetErrorString(retVal), NULL, MB_OK);
 gflFreeBitmap(pBmp);
 return retVal;
What about the questions I asked about multipages formats?
The reply was actually an addiction appended by me...
I've tried the following code, and it works:
	gflGetDefaultLoadParams( &load_option );
	pBmp=gflAllockBitmap(GFL_BGRA,512,512,4,NULL);
	for ( y=0; y<pBmp->Height; y++ )
		ptr = gflGetBitmapPtr( pBmp, y );
		for ( x=0; x<pBmp->Width; x++ )
			*ptr++ = 0;
			*ptr++ = 0;
			*ptr++ = 255; // red
			*ptr++ = 0;
	save_params.FormatIndex=gflGetFormatIndexByName("bmp");
	gflSaveBitmap("d:/temp/test.bmp", pBmp, &save_params);
Alessandro
hi,
I tryed the code and it works, but it looks like saving in .png still there're problems, aniway thanks, it helped me.
Alessandro wrote:I tryed the code and it works, but it looks like saving in .png still there're problems, aniway thanks, it helped me.
What's happened?
Alessandro
I tryed to store into a png file an rgb32 image, but whether I set the alpha channel to 0 or to 255 the images looks transparent (format of my data is in DWORDs: AARRGGBB, format set as parameter in save function: GFL_BGRA).
I solved it converting in RGB24 but I can't figure out what's the problem.
Maybe when (and if) I'll try to store a transparent image I'll get it.
Thanks for your help.
