How do I change zoom management?
sebView
How do I change the zoom management? As of now it is logarithmic, increasing with bigger steps the more zoomed in. Is it possible to change the behavior of the zooming so that each mouse wheel step zooms in a fixed level, for example +/- 15% zoom regardless of how zoomed in the image is at the moment?
Re: How do I change zoom management?
Tools > Settings... > View -- View tab has that option among others...sebView wrote: Mon Jul 29, 2019 8:14 pm How do I change the zoom management? As of now it is logarithmic, increasing with bigger steps the more zoomed in. Is it possible to change the behavior of the zooming so that each mouse wheel step zooms in a fixed level, for example +/- 15% zoom regardless of how zoomed in the image is at the moment?
Lots more options in Tools > Settings... so worth browsing!
