Transparency is lost during conversion from CMYK to RGB
tomilipin wrote: Sun Jul 28, 2019 5:33 pmI'm working on a TIFF file with transparent background, which shows correctly in Windows 7 generic image viewer, but in XnView the background is white - no idea why...
I'm using XnView 2.48, Windows 7.
tomilipin wrote: Tue Jul 30, 2019 4:52 pmAnyway, here's the file: http://wikisend.com/download/927280/Zywiec.tif
Bug confirmed :bugconfirmed:
Activating/disabling color management doesn't make any difference.
xnview wrote: Wed Apr 12, 2017 12:45 pmTo be able to convert correctly this CMYK image, you need to use a CMYK default color profile like this one cmyk.zip
ToolsOptions…GeneralICCDefault CMYK color profileOther [ X:\Test\cmyk.icm ]
Re: Transparency is lost during conversion from CMYK to RGB
is it possible to have the file, the link has expired
