Opening TG4 File
baijuku
Opening TG4 File
Post by baijuku »
Hello
I have tried to open .TG4 file in the XnView Software. However it is not opening the file. It is showing an error
INGR: Data type code not supported.
I tried in XnConvert as well. It is not working. It has identified the file as Intergraph Raster bitmap.
But it is not converting.
I have to convert a set of TG4 to PDF. Any help highly appreciated.
Thanks
Baiju
Re: Opening TG4 File
baijuku wrote: Wed Jul 31, 2019 8:00 am I have tried to open .TG4 file in the XnView Software. However it is not opening the file. It is showing an error
Are you able to upload an example file, you will probably need to place it in a ZIP, 2MiB the current forum attachment limit...
baijuku
Post by baijuku »
Please see the attached sample file
this TG4 comes from which software?
