Import 310 directories
elfroggio
Post by elfroggio »
Linux Opensuse Leap 15.1.
How can I import 310 directories/folders? I have a total of 48,000 images in there
All the images are underneath the /drive-b/photos/ directory. /drive-b/ is a 4TB internal drive /dev/sdb which is separate from the rest of the system.
Thanks
Re: Import 310 directories
Post by michel038 »
These photos do contain keywords ? iptc ? xmp ? xmp companion ?
Do you have already created some of these keywords as categories in xnviewmp ?
Did you backup some settings, categories, xnview.db ... before adding so much photos ?
If yes, go to settings metadata, mark the first checkbox (import xmp .. iptc .. to categories ), unmark the second (export)
go to settings catalog, click on "add folders" and choose the directory that contains your photos to be added ...
it will take a few hours to read 48000 files
When finised, you'll be able to use categories filter.
in settings metadata you can now unmark "import ..." and set "export ..." , so keywords will be added when you check a category.
( If there are no keywords at all in these photos, you can use ExifTool to copy folder names into keywords, but it's a bit tricky ...)
elfroggio
Post by elfroggio »
michel038 wrote: Wed Jul 31, 2019 10:30 pm These photos do contain keywords ? iptc ? xmp ? xmp companion ?
I would say that about half of them have keywords and they are stored in .cr2.xmp and .raf.xmp
michel038 wrote: Wed Jul 31, 2019 10:30 pm Do you have already created some of these keywords as categories in xnviewmp ?
I have a spreadsheet with all my keywords. I could even create them by hand if "really" needed. There are less 350 keywords in all.
michel038 wrote: Wed Jul 31, 2019 10:30 pm If yes, go to settings metadata, mark the first checkbox (import xmp .. iptc .. to categories ), unmark the second (export)
I tried this twice and it crashed about a third of the way through. The second time, I deleted all the xnviewmp config before trying to import again.
GFF :: LoadThumbnail : 2
 CHECK : <coren-stan-20180727-a002-5x7-vertical.xcf>
LOAD BITMAP </drive-b/photos/gimps/coren-stan-20180727-a002-5x7-vertical.xcf>
*** Error in `/tmp/.mount_xnniewayDVaX/usr/XnView/XnView': double free or corruption (!prev): 0x00007f01741c1b60 ***
/tmp/.mount_xnniewayDVaX/usr/bin//xnviewmp: line 5: 31627 Aborted                 (core dumped) "$usr/XnView/XnView" "$@"
Thanks
elfroggio wrote: Thu Aug 01, 2019 12:03 am
is it possible to have the .xcf file?
elfroggio
Post by elfroggio »
xnview wrote: Mon Aug 05, 2019 3:34 pm
Actually, there are 2 files:
https://drive.google.com/open?id=1vDHCf ... hA-J5VzHc1
and
https://drive.google.com/open?id=1nsoyE ... AoZl5Gh5gx
If XnV can't read them , what about ignoring them completely?
Thanks
elfroggio wrote: Sun Aug 11, 2019 4:13 am If XnV can't read them , what about ignoring them completely?
Xn can read .xcf. Are you using 0.93.1? I can't reproduce the crash
elfroggio
Post by elfroggio »
xnview wrote: Mon Aug 12, 2019 10:51 am
I'm using Opensuse Leap 15.1 and the crash was with
xnview_mp.glibc2.17-x86_64.appimage
downloaded from: https://download.xnview.com/XnView_MP.g ... 4.AppImage
I even told it to ignore that directory (with most of my gimps/xcf files) and it still crashed.
Is there a way to tell it to ignore some file extensions?
Thanks
elfroggio wrote: Tue Aug 13, 2019 12:53 am downloaded from: https://download.xnview.com/XnView_MP.g ... 4.AppImage
Right, strange, i can only reproduce with this AppImage, not the TGZ or deb
You can add .xcf in Settings>Filelist>Custom filter - Exclude
elfroggio
Post by elfroggio »
xnview wrote: Wed Aug 14, 2019 12:58 pm
Adding ".xcf" in 'Settings>Filelist>Custom filter - Exclude' doesn't work, it still crashes xn
Thanks
do you use Filter>Custom?
elfroggio
Post by elfroggio »
xnview wrote: Thu Aug 15, 2019 12:27 pm do you use Filter>Custom?
No: settings > borowser > file list > file operations > exclude
Thanks
no in Browser, View>Filter by>Custom
elfroggio
Post by elfroggio »
xnview wrote: Fri Aug 16, 2019 6:57 am no in Browser, View>Filter by>Custom
I don't see, I did: but there's nothing allow me to select images without the gimps xcf. When I press enter while highlighting custom: nothing happens
Thanks
elfroggio wrote: Thu Aug 15, 2019 5:41 pm Image
Here you need to check the 'show as thumbnail' for exclude
elfroggio
Post by elfroggio »
xnview wrote: Mon Aug 19, 2019 8:08 am
Still no success. :shock:
I get the following error:
GFF :: LoadThumbnail : 0
 CHECK : <bizcard-sritch-20181101.xcf>
LOAD BITMAP </drive-b/photos/business/bizcard-sritch-20181101.xcf>
ItemData :: update ==> business OK
 CHECK : <agility-20100612-8158-edit.psd>
LOAD BITMAP </drive-b/photos/gimps/agility-20100612-8158-edit.psd>
  JPEG load : 1.044444  90 62
  JPEG load : 160 94
 CHECK : <agility-20100612-8158-edit.psd.xmp>
LOAD BITMAP </drive-b/photos/gimps/agility-20100612-8158-edit.psd.xmp>
my_error_exit...<Not a JPEG file: starts with 0x3c 0x3f>
ItemData :: update ==> customers OK
ItemData :: update ==> events OK
*** Error in `/tmp/.mount_xnview05iPoa/usr/XnView/XnView': double free or corruption (!prev): 0x00007fec10097260 ***
/tmp/.mount_xnview05iPoa/usr/bin//xnviewmp: line 5:  9382 Aborted                 (core dumped) "$usr/XnView/XnView" "$@"
froggy@etherlbert:~>
I included a few more than the image xnviewmp crashes on. See: /bizcard-sritch-20181101.xcf which is OK
In /tmp, I have
> ls -alF /tmp/qts*
-rw-r--r-- 1 froggy users 0 Aug 14 11:53 /tmp/qtsingleapp-XnView-19c-3e8-lockfile
srwxr-xr-x 1 froggy users 0 Aug 15 10:37 /tmp/qtsingleapp-XnView-2b96-3e8=
-rw-r--r-- 1 froggy users 0 Aug 15 10:37 /tmp/qtsingleapp-XnView-2b96-3e8-lockfile
-rw-r--r-- 1 froggy users 0 Aug 15 10:37 /tmp/qtsingleapp-XnView-308d-3e8-lockfile
-rw-r--r-- 1 froggy users 0 Aug  1 09:55 /tmp/qtsingleapp-XnView-3612-3e8-lockfile
-rw-r--r-- 1 froggy users 0 Aug  1 09:57 /tmp/qtsingleapp-XnView-378a-3e8-lockfile
srwxr-xr-x 1 froggy users 0 Aug 14 11:50 /tmp/qtsingleapp-XnView-52c8-3e8=
-rw-r--r-- 1 froggy users 0 Aug 14 11:50 /tmp/qtsingleapp-XnView-52c8-3e8-lockfile
srwxr-xr-x 1 froggy users 0 Aug 16 09:52 /tmp/qtsingleapp-XnView-5572-3e8=
-rw-r--r-- 1 froggy users 0 Aug 16 09:52 /tmp/qtsingleapp-XnView-5572-3e8-lockfile
-rw-r--r-- 1 froggy users 0 Aug 15 10:36 /tmp/qtsingleapp-XnView-5ac6-3e8-lockfile
srwxr-xr-x 1 froggy users 0 Aug 14 11:54 /tmp/qtsingleapp-XnView-79f1-3e8=
-rw-r--r-- 1 froggy users 0 Aug 14 11:54 /tmp/qtsingleapp-XnView-79f1-3e8-lockfile
srwxr-xr-x 1 froggy users 0 Aug 14 11:52 /tmp/qtsingleapp-XnView-8466-3e8=
-rw-r--r-- 1 froggy users 0 Aug 14 11:52 /tmp/qtsingleapp-XnView-8466-3e8-lockfile
srwxr-xr-x 1 froggy users 0 Aug 12 17:50 /tmp/qtsingleapp-XnView-86a3-3e8=
-rw-r--r-- 1 froggy users 0 Aug 12 17:50 /tmp/qtsingleapp-XnView-86a3-3e8-lockfile
-rw-r--r-- 1 froggy users 0 Aug  1 09:57 /tmp/qtsingleapp-XnView-a13d-3e8-lockfile
-rw-r--r-- 1 froggy users 0 Aug 14 11:51 /tmp/qtsingleapp-XnView-a870-3e8-lockfile
srwxr-xr-x 1 froggy users 0 Aug 19 17:13 /tmp/qtsingleapp-XnView-b150-3e8=
-rw-r--r-- 1 froggy users 0 Aug 19 17:13 /tmp/qtsingleapp-XnView-b150-3e8-lockfile
-rw-r--r-- 1 froggy users 0 Aug  1 10:14 /tmp/qtsingleapp-XnView-b9eb-3e8-lockfile
srwxr-xr-x 1 froggy users 0 Aug 19 17:16 /tmp/qtsingleapp-XnView-d9c-3e8=
-rw-r--r-- 1 froggy users 0 Aug 19 17:16 /tmp/qtsingleapp-XnView-d9c-3e8-lockfile
-rw-r--r-- 1 froggy users 0 Aug 12 17:44 /tmp/qtsingleapp-XnView-da4e-3e8-lockfile
-rw-r--r-- 1 froggy users 0 Aug  1 18:25 /tmp/qtsingleapp-XnView-ea3-3e8-lockfile
-rw-r--r-- 1 froggy users 0 Aug 16 09:53 /tmp/qtsingleapp-XnView-f7cd-3e8-lockfile
srwxr-xr-x 1 froggy users 0 Aug 19 17:14 /tmp/qtsingleapp-XnView-fb8e-3e8=
-rw-r--r-- 1 froggy users 0 Aug 19 17:14 /tmp/qtsingleapp-XnView-fb8e-3e8-lockfile
Thanks
