Video playback : cursor stuck
Gwenouille
Post by Gwenouille »
Hello there.
I have made a quick search but could not find a solution to my problem. Here it is:
I use XnView MP 0.93.1 on Win 10 64 Home.
When I watch a video, I am able to navigate with the cursor.
But if I select another video from the same folder, the cursor is useless: I can watch the video but can't navigate using the cursor nor by clicking on the timeline...
For it to work again, I have to navigate to a video in another folder. Then it will work as normal ... until i view another video of that folder.
This behaviour is not new: i hope everytime i see an update that it'll be fixed.
Has anyone noticed it too ?
Re: Video playback : cursor stuck
you can reproduce everytime?
Gwenouille
Yes, absolutely.
It happens everytime, and with any sort of video files. It is NOT restricted to, say, mp4 or mov files, every file extension is concerned.
I have made a small test and can bring some precision:
If I stay within the same folder, I can click on an image to have its preview, and after that click to another video and it will be fine.
SUMMARY
video -> video : bug
video -> image -> video : ok
video -> change directory and select video -> ok
I can't reproduce. Please try to edit xnview.ini, and change
useInternalVideoPlayer=false
Gwenouille
Waw ! That does the trick !
Thanks a lot !
