How can i create multipage PDF file from set of images?
I can only made one page from one image.
multipage PDF
Not PDF
- As far as I see on the output format combobox, there is not any PDF - which is a compiled format - but Adobe PhotoShop, that is different, except I mistake…
Re: multipage PDF
Currently not possible, but perhaps i'll add it soonak73 wrote:How can i create multipage PDF file from set of images?
t(r)opdude
I badly need the same
- multipage .doc or .pdf options of the contact sheets.
Thanks!
Thanks!
andreasm82
When will this be possible?
I've some jpegs and want to create one PDF file of it...
My private (german) page www.energie-bewusstsein.de
andreasm82
ckv
That will be, after summer I believe.andreasm82 wrote:Can you estimate when this will be?
