When I create a contact sheet, I can choose the size of the sheet between a3, a4, and so on, but not the orientation of the sheet (portrait/landscape).
Even more important, the choosen size will not be saved, so i have to type 29,7 cm x 21 cm every single time. This must not be, I think, and this is my suggestion.
Thanx for reading / implement ancd compliment for the BEST image archiver of the worls.
Features / Create contact sheet
Re: Features / Create contact sheet
Easy to do for Pierre. Just to add some more presets OR (perhaps better) a button to switch Width and Height.I can choose the size of the sheet between a3, a4, and so on, but not the orientation of the sheet (portrait/landscape).
For me, the last size is saved.Even more important, the choosen size will not be saved, so i have to type 29,7 cm x 21 cm every single time.
Do you want to save a preset? This needs a little more work (a dialog, Add/(re)name/Delete buttons etc.) - If Pierre has a text file with the presets perhaps you can edit it directly.
m. Th.
