Thumbnails not refresh
Yakano
Post by Yakano »
when I change orientation, size, colors, etc... in a photo, the thumbnail don't shows the changes. Is that right? Am I wrong? Can I configure some parameter to aply changes to thumbnail?
You can see an example:
Regards :mrgreen:
marsh
Re: Thumbnails not refresh
Post by marsh »
Yakano wrote:Hi,
Unselecting Option>Browser>Thumbnail> '[ ] Use embedded thumbnail' should help.
Yakano
Post by Yakano »
Hi marsh
I have changed the option you wrote and some thumbnails has been refreshed, but some others not does. Just selected file in example is one of them.
Some idea?
Yakano
Post by Yakano »
Hi, me again:
First, the option "[ ] Use embedded thumbnail" remain unselected, well, when I clik right button on file (thumbnail) and choose "Edit IPTC data..." and click "cancel" (doing really anything with IPTCdata) the problematic thumbnail changes and take right little image from modified photo using xnview.
I don't understand...
:bug: ???
XnView has a cache for thumbnails. It's very likely that XnView gets the old thumbnails from the cache. Try clearing the cache using menu item "Tools > Options...", category "Browser > Cache", "Remove all" button.
Please also have a look at related topics:
- Image view and Thumbnail don't match
- EXIF rotations are wrong
- How to rotate images automatically
Yakano
Post by Yakano »
<Moderator's note: This post has been edited>
That's right, thanks helmut :mrgreen:
