0.93.1: Zoom key only works on the first tab
riripa
Post by riripa »
Subject: 0.93.1: Zoom key only works on the first tab
XnView: MP Version 0.93.1 64bits (Mar 6 2019)
OS: Windows 10 - 64-bit
Effect: Zoom key only works on the first tab.
XnView does not zoom when pressing the '+' or '-' key on tabs other than the first tab.
1. Open first image which will open the XnView.
2. Open second image which will open the second tab on XnView.
3. Press '+' or '-' key.
Actual behaviour (bug): XnView does not zoom the image
Expected behaviour: XnView will zoom the image
Re: 0.93.1: Zoom key only works on the first tab
i can't reproduce, do you open file from XnView's browser?
riripa
Post by riripa »
xnview wrote: Mon Sep 02, 2019 5:08 pm i can't reproduce, do you open file from XnView's browser?
Here I made a video
https://streamable.com/95q28
I also tried 0.93, the key is still working fine there.
riripa wrote: Tue Sep 03, 2019 10:08 am Here I made a video
so with 'single instance', right?
the problem is only in 0.93.1?
riripa
Post by riripa »
xnview wrote: Tue Sep 03, 2019 2:12 pm
Sorry I don't understand what you meant by single instance.
Yes it's only in 0.93.1, it works fine in 0.93.
riripa wrote:Sorry I don't understand what you meant by single instance.
I think the setting referred to is Tools > Settings... > General -- General tab -- Allow only one instance of XnView
Rainmaker
Post by Rainmaker »
I have this problem too, sometimes happen with first tab as well. The main window lose focus and doesn't respond to keyboard, instead cursor get to the scale input field on the status bar.
riripa
Post by riripa »
cday wrote: Wed Sep 04, 2019 6:58 am
Yes, that option is checked on mine.
riripa wrote:Yes it's only in 0.93.1, it works fine in 0.93.
when you open the second tab, the focus is not on zoom field??
riripa
Post by riripa »
xnview wrote: Thu Sep 05, 2019 2:20 pm when you open the second tab, the focus is not on zoom field??
What do you mean by zoom field?
Anyway can you try it to reproduce it again? Just follow the exact step I showed.
riripa
Post by riripa »
I just noticed some portion of my post was gone. I revised the bug from 'Zoom only works on first tab' to 'Zoom is not working on the last tab'.
As shown on the video above, I can't zoom the 2nd tab but after I open the 3rd tab, I can zoom the 2nd tab but unable to zoom on the 3rd tab.
Rainmaker
Post by Rainmaker »
For me it's like riripa said, focus is on zoom field only at last tab or if it is the only tab.
riripa wrote: Fri Sep 06, 2019 2:11 am
in this field?
