After updating Windows 10 to version 1903, it is not possible to switch the image from the browser to the fullscreen display.
(From viewer it works)
Thanks for any idea.
Marffy
edit:
Deleting the INI or reinstalling the program was not enough.
Trouble with fullscreen
Re: Trouble with fullscreen
what's happened?
Marffy
I don't know, I probably need to reinstall Windows.
Marffy
strange, do you have multiple monitor? even if you delete xnview.ini?
Marffy
BINGO!
I have one monitor, but windows detected two.
Helped change windows settings.
THX Marffy
THX Marffy
