MP 0.94b1: overwrite previously deleted file
dergilbwillspam
Post by dergilbwillspam »
XnView: MP ?–0.94b1 64 bit
OS: Windows 10 Pro #1903 64bit
When I print a picture with the "Microsoft Print to PDF" printer, I get the "Save Print Output As..." dialog. If I wanted to name the file "test.pdf" and the folder already contains a "test.pdf", and I delete that file in this dialog, I still will be asked if I wanted to overwrite that file.
Effect: Unnecessary dialog.
(At some point in the past, XnView MP would save the file as "test (1).pdf", IIRC. Now it overwrites the file and keeps the name, as it should be.)
1. Have a file named "test.pdf" in folder x
2. Attempt to "Print" an image with the "Microsoft Print to PDF" in that folder. (Attempt means: don't save yet, just go to folder x)
3. Delete the file from 1.
4. Now continue to save the file as "test.pdf"
5. You will be asked if you want to overwrite "test.pdf"
Actual behaviour (bug): :bug:
XnView asks if I want to overwrite a file that doesn't exist any longer.
Expected behaviour:
XnView doesn't ask if I want to overwrite a file that doesn't exist any longer.
