I have selected labels "Filename", "EXIF:Model" & "EXIF Focal length" and these are all displayed under the thumbnails of existing files.
If I create new images within a currently displayed folder using an external editor, new thumbnails are displayed as expected. However, only the filename is displayed (the Exif labels are blank).
View > Refresh: does nothing
Opening Settings then clicking OK: the missing Exif labels appear.
XNView MP version 0.93 94bit
Windows 7 Home 64bit
Exif labels are not displayed for thumbnails of new files.
davescape
Re: Exif labels are not displayed for thumbnails of new files.
Are you able to reproduce with 0.95?
