Hi.
Have installed XnView MP onto a computer running Fedora 30, x64, Cinnamon.
Whenever I start XnView MP, the Startup Wizard dialog opens first. This happens if I open the program via menu and also if I open XnView from file explorer (double click on a jpg file for example).
The full command from launcher (aka. start menu) is:
/usr/bin/flatpak run --branch=stable --arch=x86_64 --command=xnview --file-forwarding com.xnview.XnViewMP @@ %F @@
Is there any settings I can do in order to prevent this menu opening up every time XnViewer MP opens ?
Always open with Startup Wizard - Fedora 30 / Flatpak
Sprintdriver
Re: Always open with Startup Wizard - Fedora 30 / Flatpak
if you start it from shell console, no problem?
Sprintdriver
Thing is - I'd used the "ln -s" command to redirect the /home/sprintrdriver/.var/app/com.xnview.XnViewMP to some folder in the /var directory (simply because I have a separate partition for /var that has plenty of space) - not realizing all the flatpak apps are running in a sandbox environment, not supposed to have access to /var.
I didn't realized it before now.[edit]
No - it was something else. I was wrong. I tested this, and renamed the folder .var in homedir to something else, so that XnViewMP created the directory over again. So I expected the problem to be solved, but no. I still get this dialog box every start - and also XnVIewMP seems unable to save ANY settings.
Terminal output
Terminal output
[sprintrdriver@localhost ~]$ /usr/bin/flatpak run --branch=stable --arch=x86_64 --command=xnview --file-forwarding com.xnview.XnViewMP
==> 1.000000 91.793814 96.000000 (0)
XNVIEW restoreGeometry before : 640 480
XNVIEW restoreGeometry after : 850 620
w.init
XNVIEW SIZE 850 620
########### BrowserWindow :: BrowserWindow
libpng warning: iCCP: known incorrect sRGB profile
MENU install : 0x31e6760
ThumbLoaderThread :: stop()
### ThumbLoaderThread :: stop() ok
########### BrowserWindow :: ok create (640 480)
BrowserWindow :: changeVisibility()
########### BrowserWindow :: restoreState (850 620)
BrowserWindow :: restoreState => 850 620
=> 588 410
BrowserWindow :: restoreState ok => 588 410
XNVIEW SIZE ok
w.start
### BrowserWindow :: onStart go
#### onFavoriteDockVisible (1)
BookmarkNode::BookmarkNode : 0x3414b50
#### onCategoryFilterDockVisible (1)
#### onCategoryDockVisible (1)
########### BrowserWindow :: restoreState (850 588)
BrowserWindow :: restoreState => 850 588
=> 588 233
BrowserWindow :: restoreState ok => 588 233
BrowserWindow :: onStart 2
setPathname </home/geir/>
### ThumbLoaderThread :: setFileList(0)
### ThumbLoaderThread :: setFileList() wait
######ThumbLoaderThread :: run : 32c5150
######ThumbLoaderThread :: forever : 32c5150
** start condition wait
### ThumbLoaderThread :: setFileList() after wait
** start condition wake one 2
######ThumbLoaderThread :: forever 2 : 32c5150
CHECK <0>
## OPEN FOLDER
## OPEN DB FOLDER ok
## UPDATE DB FOLDER ok
## OPEN FOLDER ok
## updateLabels
## updateLabels ok
######### CategoryModel :: checkAndSave()
TIME 0
BitmapLoadThread :: stop()
QObject::disconnect: No such signal CategoryView::selectionChanged(const DBFilterModel::DBFileList&)
QObject::connect: No such signal CategoryView::selectionChanged(const DBFilterModel::DBFileList&)
Create children /home/sprintrdriver/
## OPEN FOLDER done
### ThumbLoaderThread :: setFileList(11)
### BrowserWindow :: finish
CHECK <10>
### START 11
######ThumbLoaderThread :: start : 10
CHECK : <XnView_MP.glibc2.17-x86_64.AppImage>
LOAD BITMAP </home/sprintrdriver/Downloads/XnView_MP.glibc2.17-x86_64.AppImage>
MyDirModelThread :: run
my_error_exit...<Not a JPEG file: starts with 0x7f 0x45>
ItemData :: update ==> Desktop OK
ItemData :: update ==> Documents OK
sizeHints : 128
sizeHints : 128
GFF :: LoadThumbnail : 2
CHECK : <Screenshot from 2019-09-01 20-19-52.png>
LOAD BITMAP </home/sprintrdriver/Pictures/Screenshot from 2019-09-01 20-19-52.png>
###### onChildrenChecked 7 <Videos>
###### onChildrenChecked 6 <Templates>
###### onChildrenChecked 5 <Public>
###### onChildrenChecked 4 <Pictures>
###### onChildrenChecked 3 <Music>
###### onChildrenChecked 2 <Downloads>
###### onChildrenChecked 1 <Documents>
###### onChildrenChecked 0 <Desktop>
ItemData :: update ==> Downloads OK
ItemData :: update ==> Music OK
GFF :: LoadThumbnail : 0
CHECK : <Screenshot from 2019-09-01 20-44-19.png>
LOAD BITMAP </home/sprintrdriver/Pictures/Screenshot from 2019-09-01 20-44-19.png>
ItemData :: update ==> Pictures OK
ItemData :: update ==> Public OK
ItemData :: update ==> Templates OK
LOAD BITMAP </home/sprintrdriver/balenaEtcher.AppImage>
GFF :: LoadThumbnail : 0 0 (2)
ThumbLoaderThread - ADD into DB (-1)
LOAD BITMAP </home/geir/skript.sh>
my_error_exit...<Not a JPEG file: starts with 0x65 0x63>
ItemData :: update ==> Videos OK
ItemData :: update ==> balenaEtcher.AppImage OK
ItemData :: update ==> skript.sh OK
### ThumbLoaderThread :: setFirstItemToLoad
** start condition wake one 3
### ThumbLoaderThread :: setFirstItemToLoad ok
CHECK <0>
CategoryThread :: run
SAVE : 850 588
BrowserWindow :: saveState => 850 588
=> 588 233
######ThumbLoaderThread :: run : 32c5150 OK
QMutex: destroying locked mutex
AFTER WAIT
BookmarkNode::~BookmarkNode : 0x3414b50
[sprintrdriver@localhost ~]$-
Sprintdriver
Update:
I installed Fedora 30 Mate on another computer. Then I installed XnView MP flatpak - didn't touch anything else. Seems to work properly now, so maybe I just did something wrong during or after installing on the other computer (Fedora 30 Cinnamon)
Sprintdriver
Went back to the other computer that run Fedora 30 Cinnamon.
I uninstalled XnVIew (flatpak).
Then I removed the .var folder in my home dir.
Then I installed XnView again.
And the problem still persists. That is - it seems like the flatpak variant of XnVIew runs just fine on Fedora 30 Mate, but not on Fedora 30 Cinnamon
Edit
The appimage version of XnViewMP works without any problems on Fedora 30 Cinnamon, I use that as it works for me
Edit
