IPTC view
PeterG
IPTC view
Post by PeterG »
Great program for editing IPTC information on multiple files. :D
One question regarding the display of the IPTC.
I have looked at all the 'view' options. However I can not find one that allows for a view of the IPTC or EXIF in a window pane. The only way to view that information is by right clicking on the image and then viewing properties.
Does anyone know if there is a View window available for displaying the IPTC as I scroll through the images?
Thanks.
Peter
Re: IPTC view
PeterG wrote:...Does anyone know if there is a View window available for displaying the IPTC as I scroll through the images?
Currently, there is the property dialog for viewing IPTC information, only. So you cannot navigate through images and view the IPTC data without opening and closing the property dialog.
