Suggestion: When RAW file is loaded warn to select image version to be used
As RAW files normally contain multiple image size versions, a warning when a file is loaded to select the image size to be used on the Setting tab Load format settings... would avoid possible confusion when the output file is not as expected.
Possibly triggered when a RAW file has been loaded and Convert is clicked?
