I decided to use XNView MP instead of classic because classic doesn't seem to be able to view video files.
I can't find any option to hide the folder/file view. Is it possible?
Also, is it possible to bind key shortcuts to move a picture directly to a specific folder?
How to hide the file/folder list?
Re: How to hide the file/folder list?
I'm not sure...jokooon wrote: Fri Sep 06, 2019 9:56 am I decided to use XnView MP instead of Classic because Classic doesn't seem to be able to view video files.
If the browser is open, you should be able to close its tab at the left?I can't find any option to hide the folder/file view. Is it possible?
To control whether the browser is displayed:
Tools > Setting > General -- General tab -- Startup -- Open browser
Someone else?Also, is it possible to bind key shortcuts to move a picture directly to a specific folder?
jokooon
Well it seem that I have .mp4 files that are crashing XNView MP
Basically .GIF hosted by reddit on i.redd.it or v.redd.it are h264/AVC/MP4/whatever.
Attached the file in question
