.HDR files incorrect color mapping
linys820
Post by linys820 »
Hello! Here are some HDR files thumbnails displayed under Windows 10 explorer. They look correct.
When using XnView to browse HDR files, the problem of incorrect color mapping appears. Both in browser and viewer.
I tried to change the gramma 2.2 to other value, but they still look bad.
I opened the HDR files in Photoshop, save them as OpenEXR(.exr) and they look good in XnView.
Hope you can fix it soon. Thank you!
You can go to http://hdrihaven.com/hdris/ to download some high-resolution HDR images, without registration or login.
Re: .HDR files incorrect color mapping
do you have changed the gamma in settings>Read>HDRI?
