custom key cmd_fileNext does not work in Fullscreen mode
jaybee604
Post by jaybee604 »
it seems that assigning a custom key to "cmd_fileNext"" has no effect in fullscreen mode.
the left/right/up/down cursor keys which can be configured under settings/interface/keyboard do work but I would like to use the SPACE key to navigate to the next picture. This does work in windowed mode but not while in fullscreen. I tested this also with other keys like j,k,l - same effect.
Thanks a lot if that can be fixed.
jaybee604
Re: custom key cmd_fileNext does not work in Fullscreen mode
Post by jaybee604 »
Ok the issue is over. I am not 100% sure why it is working now as expected but it might be due to that when a key is assigned to cmd_fileNext manually then both - the manual assignment AND the SPACE key configuration under settings/interface/keyboard have no effect in fullscreen mode. So it seems that the manual key config for cmd_fileNext must be set to NONE or STANDARD. Then the SPACE key is working also in fullscreen mode.
