I have the problem that XnViewXP doesn't show me thumbnails for *.jpg. For other formats e.g. RAW it works.
I have already reinstalled but without success.
Anyone have
an idea why?
henzie
henzie
Re: XnViewXP doesn't show me thumbnails for *.jpg
yes, i installed XnView again to test it, it works with the display of the jpg
Are you saying that no JPEGs on your computer have a thumbnail, or only some JPEGs have no thumbnail?henzie wrote: Sun Sep 08, 2019 2:55 pm yes, i installed XnView again to test it, it works with the display of the jpg
It seems improbable that you are only looking at malformed JPEGs in the browser, but you could try enabling the following option in the viewer and see if it has any effect:
File > Format settings... > Read tab -- Ignore read errors
henzie
all jpg files but only for XnView MP, for XnView they are displayed
i've tried that, but no change
and the same with XnView
which filters do you use?
henzie
no filter.
no filter.
View>Filter By?
henzie
Please see attachment
henzie
Hello Pierre,
please see attachment.
no problem with this file. Could you try to rename your xnview.ini, and start with a clean one?
henzie
Many Thanks, this was the Problemxnview wrote: Mon Sep 16, 2019 5:28 am no problem with this file. Could you try to rename your xnview.ini, and start with a clean one?
