Icc Profile? Color Management
Idealys
Post by Idealys »
I use XN view to manage pitures i have taken with a digital SLR.
I take all my pictures in RAW format and then i use C1 pro 3.5 to correct the exposure... an convert them to jpeg.
I use a screen Calibrator in order to have the exact same colors on screen then on print.
The problem is that the Jpeg have the same colors on C1 pro, Photoshop and even on windows explorer, but the colors go funy with XNview.
does anyone know how to atribute the Icc profile generated with my screen calbrator to XNview?
Thanks
Re: Icc Profile? Color Management
Idealys wrote:Hi,
Currently icc profile are not supported, but it's in my TODO list. Could you send me a sample, please?
Idealys
ICC color management
Post by Idealys »
OF course but what sample di you want?
the ICC file itself?
Re: ICC color management
Idealys wrote:OF course but what sample di you want?
A tiff sample with ICC profile.
nyc_ps
Any update?
Post by nyc_ps »
Is there any update as to when you may start handling color profiles?
Re: Any update?
nyc_ps wrote:Is there any update as to when you may start handling color profiles?
Not yet, i must change many things before to support it
TM
missing colormanagement
Post by TM »
missing colormanagement is the only reason I use Nikon View in parallel to XNVIEW.
For me, CM would be very helpful...
Ciao, TM
JohnLakkas
Color managment
Post by JohnLakkas »
Do you still want the sample images? How can we send you some samples? Tiffs are quite big but jpgs are fine.
Re: Color managment
JohnLakkas wrote:Do you still want the sample images? How can we send you some samples? Tiffs are quite big but jpgs are fine.
Yes, please send me it
JohnLakkas
I did send you an email with details and sample pictures.
Post by Guest »
while XnView is the best I don't use it due to the lack of cms support.
Too bad !
Anonymous wrote:Hi,
Too bad !
I'll try to add cms in next version...
Svenne
Post by Svenne »
Would be grate, when i show pictures with Adobe RGB profile embedde the colors are displaing wrong.
mullEY
Post by mullEY »
xnview wrote:
Anonymous wrote:Hi,
Too bad !
CMS would be awesome, only thing that's missing, really. Anyway XnView is a great job!!! keep goin' :wink:
riemenschneider
Post by riemenschneider »
Color-Managment capabilities would be gorgeous!! Let me know if you need any test-files (Nikon-RAWs, Tiffs, JPGs with or without profiles...)
riemenschneider
