Hi there, Im new with xnfiewmp portable on win vista 32 pc.
I try to turn and cut the pages of an multible pdf-scan file.
When I turn or cut one page, go on to the next and then go back, xnfiewmp doesnt save the changes.
Dont know if it is a bug or did I miss out on something.
Could somebody help?
edit multipage pdf images
Re: edit multipage pdf images
Could you try saving the PDF file before going to the next page, I think that will work...Muesmoa wrote: Wed Sep 18, 2019 3:30 pm Hi there, I'm new with XnView MP portable on win vista 32 pc.
I try to turn and cut the pages of an multiple page pdf-scan file.
When I turn or cut one page, go on to the next and then go back, XnView MP doesn't save the changes.
If there are a large number of pages and saving the file becomes slow, it is possible using functions in the browser to extract the pages, edit them individually, and then create a new multipage PDF file.
Edit:
I recall now that some XnView software may only save the first page of a multipage file, a limitation to be addressed I believe.
If you need to perform identical operations on all pages, you can do that directly using XnConvert by configuring the Output tab to suit.
