I'm converting PSD files with a rec709 ICC to PNG. I notice that the ICC profile is not embed on the PNG.
It stay embed when exporting JPEGs.
Can you have a look into it?
Thanks,
Andrea
Embed ICC Profile not working when exporting PNG
andreamike
Re: Embed ICC Profile not working when exporting PNG
You have in the Output tab 'Preserve color profile' selected, do you?andreamike wrote: Thu Sep 19, 2019 7:10 pm Hello,
andreamike
Yes, 'Preserve color profile' is enable. It works when exporting JPGs but not PNGs.
could you send me the PSD file?
andreamike
Yes, of course. How can I send it to you?
This happen also from JPG (with ICC embedded) to PNG. xnconvert or view remove the ICC from the process.
andreamike
Thanks,
Do you know if and when the fixed version will come out?
