How to show EXIF "Lens Type" in info overlay?
Ihaveaproblem
Post by Ihaveaproblem »
Hi!
I am unable to find the correct expression for displaying the name of the lens in the info overlay (I key). The files from my camera (Panasonic Lumix G-81) have an EXIF-Field, that is named "Lens Type" when viewed in the EXIF Side Panel and has a value of (for example) "LEICA DG MACRO-ELMARIT 45/F2.8". I was trying to find out the exact field name that must be used in the F12 settings for this information to display in the info overlay. I tried among several other variations (guessing):
{Filename With Ext}
{EXIF:Date [d.m.Y H:M]}
f{EXIF:F-Number} {EXIF:Exposure Time}s i{EXIF:ISO Value} {EXIF:Focal Length 35mm}mm
{EXIF:Lens Type}
...but the expression in the last line is not evaluated.
Any help would be much appresciated.
Thanks!
8)
\Nick
Re: How to show EXIF "Lens Type" in info overlay?
sorry currently no way
Cavaler
Post by Cavaler »
And still no way to do it? That should not be that difficult, since this information is seen image info under "Makernotes"...
Fotograf4848
Post by Fotograf4848 »
Is there a list of all info that could be shown in overlay? For example I'd like to show the Exposure bias value.
you have the menu for example in Settings>View>Info
Fotograf4848
I know, I edited it. But there are only a few examples and not the whole possibilities. As mentioned I'm searching for Exposure bias value and some other Exif data to show.
Fotograf4848
Thanks, {EXIF:Exposure Bias} was the command I needed. Where can I see all the possible commands?
