Option to always start from bottom of folder?
andyuser99
Is there a setting where I can set XnView to always start from the bottom of folder?
Re: Option to always start from bottom of folder?
sorry but i don't understand
andyuser99
Hi Pierre, what I mean is when in browsing mode. You go into a folder, then you see thumbnails. And it starts at the top of the folder by default. And I scroll down to get to last files.
Is there away way to change setting so that it starts at the bottom end of the folder so I scroll up instead?
The reason is because all of my "recent" photos are always at the bottom of folder so every time I go into folder I always scroll to the bottom.
I know you can use "sort" files to ascending/descending order to get the recent files to go to top but I would prefer the folder browsing to start at the bottom of folder instead. Is this possible?
no sorry no way
