Seriously, I went to Tools>Options>toolbars but I can''t seem to get rid of the default toolbar bar across the top, remove it's buttons, then add back specific buttons.
I'm creating a family album and need specifically these buttons only
1. jpg lossless crop
2. copy to folder
It's a huge number of files and those are the only two buttons I need.
TIA
How to remove buttons from the toolbar, and then add them back.
DWD1961
DWD1961
Toolbar Customization: Can't remove or add buttons to toolbar
I have tried to remove buttons from the toolbar and then only add back the ones I want,but I cannot find a way to do that.
Options>Toolbars
I can't seem to remove any buttons from the toolbar, or get rid of the default toolbar.
I only want two buttons showing:
1. jog lossless crop
2. copy file to folder
What am I doing wrong?
Options>Toolbars
Re: How to remove buttons from the toolbar, and then add them back.
XnView MP, the latest software, has a highly customisable toolbar...DWD1961 wrote: Wed Oct 02, 2019 5:56 pm Seriously, I went to Tools>Options>toolbars but I can''t seem to get rid of the default toolbar bar across the top, remove it's buttons, then add back specific buttons.
2. copy to folder
I can't easily check how customisable XnView Classic is as I'm in Linux, but it is unlikely to be nearly as customisable.
- Forum Librarian
- Go to Info → About… to find the INI file location.
- Quit XnView.
- Copy & paste the following “code” to a text editor and save it as test.bar in the same folder as your xnview.ini.
[Default Toolbar] count=12 button1=17 button2=-1 button3=0 button4=-1 button5=21 button6=30 button7=12 button8=13 button9=14 button10=-1 button11=15 button12=16 [View Toolbar] count=2 button1=cmd_JPEGCrop.ico cmd1=cmd_JPEGCrop button2=39 [Browser Toolbar] count=21 button1=18 button2=10 button3=-1 button4=33 button5=27 button6=31 button7=-1 button8=29 button9=19 button10=21 button11=11 button12=30 button13=12 button14=-1 button15=13 button16=14 button17=24 button18=28 button19=-1 button20=15 button21=16 - Download cmd_JPEGCrop.ico and place it in the same folder as your xnview.ini.
- Start XnView.
- Go to Tools → Options… → Toolbar → Buttons → Buttons displayed, click on the […] button, and select test.bar.
billfilson
This worked up until I re-ran Xnview. The Crop icon did not appear in the Xnview browser's current toolbar. I could see it ok if I selected the tools=>properties "View" button. But it would not display in the default toolbar. What did I miss?? I really appreciate your effort here - thanks
UPDATE: If I open an image in a new Xnview browser page the new tool appears OK - This is good. I regard this a fixed - Thanks yet again.
