XnViewMP Thumbnail Compression
Sebster
Post by Sebster »
If I 'Rebuild thumbnails' using the button near the bottom of Settings-Browser-Catalog on a folder of pics I get a file size of 2.27 MiB. This is using Enable Catalog, Enable thumbnail caching, Compression: Lossy High Quality (WebP)
If I 'Rebuild thumbnails' using F6 or the menu on the same folder I get a file size of 8.56 MiB.
Using the first method after this will again reduce the size to 2.27 MiB.
Shouldn't these results be the same? Is compression not applied with the F6/Menu shortcut?
Re: XnViewMP Thumbnail Compression
no subfolder?
Sebster
Post by Sebster »
No subfolder
