No maps with linux opensuse
bigb262
Hi, I use XnViewMP with linux (opensuse). When i try to look to GPS in the info Window, there is no map, nothing
In the Winows version is everithing there, but i dont like Windows.
Re: No maps with linux opensuse
when launching XnView from a terminal, no warning message when loading map?
bigb262
I got a lot of messages, but I con not understand everthing:
./xnview.sh
==> 1,000000 129,482707 96,126316 (0)
XNVIEW restoreGeometry before : 640 480
XNVIEW restoreGeometry after : 850 620
w.init
XNVIEW SIZE 850 620
########### BrowserWindow :: BrowserWindow
libpng warning: iCCP: known incorrect sRGB profile
MENU install : 0x1fd7c80
ThumbLoaderThread :: stop()
### ThumbLoaderThread :: stop() ok
########### BrowserWindow :: ok create (640 480)
BrowserWindow :: changeVisibility()
########### BrowserWindow :: restoreState (850 620)
BrowserWindow :: restoreState => 850 620
=> 588 406
BrowserWindow :: restoreState ok => 588 406
XNVIEW SIZE ok
w.start
### BrowserWindow :: onStart go
#### onFavoriteDockVisible (1)
BookmarkNode::BookmarkNode : 0x2195170
#### onCategoryFilterDockVisible (1)
#### onCategoryDockVisible (1)
########### BrowserWindow :: restoreState (1920 1001)
BrowserWindow :: restoreState => 1920 1001
=> 1658 534
BrowserWindow :: restoreState ok => 1658 226
BrowserWindow :: onStart 2
setPathname </run/user/1000/doc/8e62a8c/>
### ThumbLoaderThread :: setFileList(0)
### ThumbLoaderThread :: setFileList() wait
######ThumbLoaderThread :: run : 20af1a0
######ThumbLoaderThread :: forever : 20af1a0
** start condition wait
### ThumbLoaderThread :: setFileList() after wait
** start condition wake one 2
######ThumbLoaderThread :: forever 2 : 20af1a0
CHECK <0>
## OPEN FOLDER
## OPEN DB FOLDER ok
## UPDATE DB FOLDER ok
## OPEN FOLDER ok
## updateLabels
## updateLabels ok
######### CategoryModel :: checkAndSave()
TIME 0
BitmapLoadThread :: stop()
QObject::disconnect: No such signal CategoryView::selectionChanged(const DBFilterModel::DBFileList&)
QObject::connect: No such signal CategoryView::selectionChanged(const DBFilterModel::DBFileList&)
Create children /
MyDirModelThread :: run
Create children /run/
Create children /run/user/
Create children /run/user/1000/
Create children /run/user/1000/doc/
Create children /run/user/1000/doc/8e62a8c/
## OPEN FOLDER done
### ThumbLoaderThread :: setFileList(1)
CHECK <0>
### BrowserWindow :: finish
###### onChildrenChecked 1 <8e62a8c>
###### onChildrenChecked 0 <6a4a045>
###### onChildrenChecked 8 <pulse>
###### onChildrenChecked 7 <krb5cc>
###### onChildrenChecked 6 <keyring>
###### onChildrenChecked 5 <gvfs>
###### onChildrenChecked 4 <gnupg>
###### onChildrenChecked 2 <dconf>
###### onChildrenChecked 38 <uscreens>
###### onChildrenChecked 37 <udisks2>
###### onChildrenChecked 35 <tuned>
###### onChildrenChecked 34 <tor>
###### onChildrenChecked 33 <tmpfiles.d>
###### onChildrenChecked 32 <tlp>
###### onChildrenChecked 30 <svnserve>
###### onChildrenChecked 29 <sddm>
###### onChildrenChecked 28 <screens>
###### onChildrenChecked 27 <samba>
###### onChildrenChecked 26 <rsyslog>
###### onChildrenChecked 25 <plymouth>
###### onChildrenChecked 24 <pcscd>
###### onChildrenChecked 23 <openvpn>
###### onChildrenChecked 22 <ntp>
###### onChildrenChecked 21 <nscd>
###### onChildrenChecked 19 <netconfig>
###### onChildrenChecked 18 <net-snmp>
###### onChildrenChecked 17 <mysql>
###### onChildrenChecked 16 <mount>
###### onChildrenChecked 14 <mcelog>
###### onChildrenChecked 13 <lvm>
###### onChildrenChecked 10 <issue.d>
###### onChildrenChecked 9 <irqbalance>
###### onChildrenChecked 7 <fsck>
###### onChildrenChecked 6 <firewalld>
###### onChildrenChecked 5 <dbus>
###### onChildrenChecked 3 <cryptsetup>
###### onChildrenChecked 2 <chrony-helper>
###### onChildrenChecked 1 <chrony>
###### onChildrenChecked 0 <avahi-daemon>
###### onChildrenChecked 17 <selinux>
###### onChildrenChecked 16 <sbin>
###### onChildrenChecked 14 <root>
###### onChildrenChecked 9 <lost+found>
###### onChildrenChecked 2 <borgbackup>
###### onChildrenChecked 0 <bin>
sizeHints : 128
sizeHints : 128
CHECK <0>
### ThumbLoaderThread :: setFirstItemToLoad
** start condition wake one 3
### ThumbLoaderThread :: setFirstItemToLoad ok
CHECK <0>
CategoryThread :: run
#### onCategoryFilterDockVisible (0)-
bigb262
With the version from flatpak is everthing good!
GalmOne
Great if it worked, that's what I wanted to recommend when I opened the thread
I had the same issue, reinstalled the Flatpak version, and it started functioning as intended.
