Print multiple photos with filename
PhXcmp
Post by PhXcmp »
I need to print about 100 photos of students and I need the filename to be beside the photo. I need to print multiple photos on A4. There is function where I can print multiple photos on 1 page, but only in predefined resolutions (would be really nice if I can set the resolution myself) but that's not the biggest problem. The problem is when I try to print them with filename under them (I really need it since I need names under the photos). If I set the resolution to 53x71mm, the photos have this resolution ... BUT ... if I add the filename, they shrink to smaller size, this problem don't occur if I print only 1 image with filename under it. Yes, I can print it that way but it's absolute waste of paper, its 10 papers vs 100 papers. And not to mention I had to print it on expensive ones. So my question is... Is there any way to print multiple photos on 1 sheet of paper with exact resolution with filename under (or above) it, or can the option be implemented in next build (I really don't know how hard it is to add such feature, I'm just asking). Thank you very much for any answers ;)
P.S.: absolutely love this software
Re: Print multiple photos with filename
do you have tried 'Thumbnails'?
