Issues with Raspian - Raspberry Pi 4
JonG
Post by JonG »
______________________________________________________
Subject: 0.92: Program does not write to config file
XnView: MP 0.92 - 32 bit
OS: Linux - ARM version ... - 32 bit
When I make changes to settings, the changes are not saved to xnview.ini, so changes are not retained once I leave the program. This is not a permissions issue, as I have made sure that the file can be changed by any user. I can manually edit the file, and the changes are retained and are in effect when I reopen the program.
Effect: Changes to setup are not saved. Changes must be made by manually editing xnview.ini
1. Open program, enter setting and make any change.
2. Exit program and reopen. Change is not saved.
Actual behaviour (bug): Changes to settings not saved :bug:
Expected behaviour: changes to settings saved.
I HAVE RESOLVED THIS PROBLEM BY REMOVING THE PROGRAM, MANUALLY DELETING THE /.config/xnviewmp FOLDER AND ITS CONTENTS AND REINSTALLING.
The following problem remains.
Subject: 0.92: Message that new version is available, when this is not the case
When I open the program, I get a notice that a new version (0.93) is available for download. However, this does not appear to be correct for the ARM version.
Effect: Annoying, incorrect notification. I have removed it by changing the check for update setting to "never".
1. Open program. Notification of new version appears.
Actual behaviour (bug): Notification of new version appears, when this does not appear to be the case. :bug:
Expected behaviour: No notification if no new version is available.
Re: Issues with Raspian - Raspberry Pi 4
yes notification is for all platforms
