I am setting up a new iMac and would like to use the settings from the old iMac.
Where are the xnview settings stored? (inf or ini files, layout files)
Any help will be appreciated!
Copy settings to new computer
toyotadesigner
hobbyists discuss new camera features
photographers discuss new software
masters discuss light
Re: Copy settings to new computer
Tools > Settings... > Integration -- Paths tab in the Windows and Linux versions, at least...toyotadesigner wrote: Tue Oct 22, 2019 10:55 am I am setting up a new iMac and would like to use the settings from the old iMac.
toyotadesigner
I didn't modify the standard settings, but the settings should be stored in the »Library« — somewhere. But I don't know where and maybe someone can give me a hint.
sasko1
I have the same "problem". Moving to new computer and would like to keep the same settings as on old one.
Any help appreciated
I've had a look at my Linux installation and clicking on the Tools > Settings... > Integration -- Paths 'Open Catalog location tab' opens the directory containing at least some of the settings files, have you tried that?toyotadesigner wrote: Tue Oct 22, 2019 12:41 pm I didn't modify the standard settings, but the settings should be stored in the »Library« — somewhere. But I don't know where and maybe someone can give me a hint.
toyotadesigner
cday, thanks for your information. I can see the location of the files by clicking the path location button — but only on the current (new) machine. And I see that it is a hidden folder: .config/...
Though I already had a new image database generated on the new machine, I will try to copy the layout settings. Trying to import the catalog files doesn't make sense anymore
