using 0.93.1
control+X / cut doesnt do its function, instead it just copies the file or folder
CUT not working
Re: CUT not working
i can't reproduce, 'Ctrl+X' always move the file
vanderzee
Re: CUT not working
it seems random, but using keyboard ctrl+x then ctrl+v offently doesn't move but copies files instead
seems that running xnviewmp as administrator solves the problem, didn't have the issua for a while
will report back if it happens again
thanks
thanks
