I've seen in the forum that it has been implemented, but XNView 1.80.3 still doesn't really support this format. It takes ages to open a folder with MRW and JPG files, finally I can see MRW thumbnails, but opening the file displays perfect black rectangle.
WBR,
Andrei.
Minolta 7D MRW support
Re: Minolta 7D MRW support
What are your settings option/Read/Camera RAW?MAV wrote:Hello,
MAV
DM
micdt
minolta raw
Minolta cams generate a seperate, corresponding thumbnail for preview purposes with the ending THM.xnview wrote:Really, i don't find a thumbnail in mrw fileDM wrote:And generating thumbnails of raw files (.MRW) is very slow =(
acd is much faster, please fix this problem
If you could use these, everbody would be happy
