Category disapear / can't add
FrankvanK
Post by FrankvanK »
I'm using XnView MP Windows, Version 0.93, with my pictures and database on a external harddisk.
I don't know if I do something wrong, but "Category"don't work very well. I do the following:
  • Select one or multiple photo's;
  • Select more categories, I want to assign to the photo’s;
  • Click on an other photo or outside the photo’s;
  • Go back to one of the photo’s which I add the category;
  • The category is not assigned to the photo !!!!
  • If you have multiple photo’s selected, sometimes there are only a few that had the catergory added to the photo’s, but not all of them
  • Sometimes it is also not possible to remove a category from a photo. I just unmark the category, go to an other photo and back to the first one the category is still there.
I have to reboot the computer and hope that the categories will work.
It takes a lot of effort to categorise the photo’s this way, because you have to check all you work twice.
Is this a know but or am I doing something wrong?
Thanks Frank
Re: Category disapear / can't add
could you post a screenshot of settings>Metadata?
FrankvanK
Post by FrankvanK »
Hi Pierre,
Here is the screenshot you asked for. Sorry it is in Dutch.
Regards Frank
FrankvanK
Post by FrankvanK »
Hi Pierre,
I put a video unlisted on YouTube so you can see what I'm doing:
https://youtu.be/1KFNI5KP-jU
Kind regards,
Frank
could you show IPTC & XMP tab info for this file?
I can't reproduce this problem
FrankvanK
Post by FrankvanK »
I don't understand what you are looking for. The file I included is not what you are looking for?
no when you click on a file in explorer, you have a EXIF/IPTC/XMP tabs
FrankvanK
Post by FrankvanK »
Hi Pierre,
You mean this files? In Dutch the tabs in Explorer has no name as "EXIF/IPTC/XMP"
The problem doesn't always happen. Sometime it does and sometimes is doesn't. If the problem happens I have to reboot the computer. Closing XnView and startup again is not fixing the problem. Now I have imported my photo's and added the categories, so this is the info of a photo with the added categories, also in XnView:
When the problem happens again, I will look if there is information is those two places.
Does this the information you need to solve this issue?
Frank
no i means that
FrankvanK
Post by FrankvanK »
Here is the information you asked for. It is from a photo with the category accepted.
bu in your screenshot, we can see that photo has a category...
FrankvanK
Post by FrankvanK »
Hi Pierre,
Yes it is possible to get the information in the files. But sometime I have to do it multiple times or shut down the computer and restart it and XnView to get the data in the file.
I don't know how to explain better, then this unlisted video on YouTube. You can see what I'm doing:
What kind of information do you need to reproduce the problem?
Kind regards,
Frank
ok, can you send me the files used?
