XnViewMP and macOS Catalina
Joreur
Post by Joreur »
Since loading macOS Catalina I can no longer open folders by dropping them onto the XnViewMP shortcut on my desktop. It still works for individual images though. Any clues?
Joreur
Re: XnViewMP and macOS Catalina
ok, i'll check, i have not yet updated to Catalina
ochmaciek
Post by ochmaciek »
I had the same on Mojave also... On my MBP I have 0.90 Version, it works properly there. You can simply drag folder on XnView app icon and it opens that folder. After update to newer version it doesn't work. Any ideas how to fix it?
Joreur wrote: Sat Nov 02, 2019 12:03 am Since loading macOS Catalina I can no longer open folders by dropping them onto the XnViewMP shortcut on my desktop. It still works for individual images though. Any clues?
I've tried but on Mojave, it's the same
samvdias
Post by samvdias »
Just downloaded XnView. A question, when I open an image on my MBP, image shows at 28%. If I tap the 1:1 button on the tool bar the image zooms in to 100% which is great. How do I zoom out back to 28% with one tap without the need to tap the - button several times? Does XnView have a feature similar to Faststone/windows where you could click anywhere on the screen and magnify that area of the screen to 100%, similar to ON1 Raw or Capture One on Mac OS X? Thank you for any advice.
samvdias wrote: Tue Dec 31, 2019 12:21 pm Just downloaded XnView. A question, when I open an image on my MBP, image shows at 28%. If I tap the 1:1 button on the tool bar the image zooms in to 100% which is great. How do I zoom out back to 28% with one tap without the need to tap the - button several times? Does XnView have a feature similar to Faststone/windows where you could click anywhere on the screen and magnify that area of the screen to 100%, similar to ON1 Raw or Capture One on Mac OS X? Thank you for any advice.
yes you can configure it in settings>Interface>Mouse
samvdias
Post by samvdias »
xnview wrote: Fri Jan 03, 2020 3:13 pm
Thank you very much. Shane
