When i return from full screen view to browser mode the current image is highlighted and the key Shift is pressed in another image all of them should be highlighted for move, copy , delete... but it doesn't happen.
In order to be able to select several images after returning from full screen it is necessary to select the current image and key Shift to the last one.
How can I avoid this? It doesn't happen in Acdsee. When return form full screen the image is already selected.
Thanks!!
Select images with Shift key in Windows
Re: Select images with Shift key in Windows
sorry but i don't understand, when you go from fullscreen to browser mode, the current file is selected...
Serena
Not, the current file not is selected.
Only the name is highlighted when return from fullscreen mode.
When click on size or other column for example then if it is selected.
sorry but i can't reproduce
Serena
The image(1) is selected as the first and key Shift is pressed up to the fifth (5). Selected total 5 images.It works well in browser mode.
If I start the full screen with the image (1), I advance two images (3) and return to the browser mode and pressing shift up to the fifth. Selected total 5 images!!! when the right thing would be from the third to the fifth (images 3 4 5).
Currently If I want to select the last three images return full screen mode, I have to click on the third one and select it, and then you select up to the fifth pressing Shift key. So if I have selected (images 3 4 5) and not from the first to the fifth.
Serena
Hi, I've tried the version v94.1 and working fine.
Thanks!!
Thanks!!
