I'm having an issue filtering my image folders. I want to keep all the images but I want to visually filter certain ones away. To do this I use the rating system and set those images to Rating 1. Then I select 'Unrated' in the 'Filter By' menu and those images disappear properly.
However my issue is that the second I quit or even change folders it resets back and shows everything, including the files I set as Rating 1. Is there anyway to save the 'Filter By' options so they persist when quitting and changing folders? I've tried using the Color system instead but that also doesn't persist.
Filter By not saving
Re: Filter By not saving
No sorry, currently only global filtering is kept (image, videos, custom, ...)
